clutch12
using dpu.ko on a custom board
i'm builiding my linux images using yocto with the meta-xilinx layer. Is there a way to add in the dpu.ko kernel module for a custom board. It seems to only support a few boards, but we are targeting a production system.
jasonwu
Hi @clutch12 ,
You can find the kernel source code inside DPU TRD design: https://www.xilinx.com/member/forms/download/design-license-xef.html?filename=zcu102-dpu-trd-2019-1-190809.zip
And for PetaLinux flow to create SW platform you can refer to: https://github.com/Xilinx/Edge-AI-Platform-Tutorials/tree/master/docs/DPU-Integration
For pure Yocto you can refer to the PetaLinux flow but you may need to add the associated custom recipes by yourself.
I would recommend you to use the PetaLinux flow if you are not very familar with Yocto, because it has more detailed step by step flow.
Best Regards,
Jason
jasonwu
Hi @clutch12 ,
Best Regards,
Jason
clutch12
thanks @jasonwu going through these links now. Is the plan to continue to release the dpu ip core as part of a TRD in an ongoing basis and not just have it be available as part of the Vivado installation? Just noting the github tutorial uses v2.0 and the trd you pointed me to is 3.0. I'm using a zcu104 board and basically starting with the the tutorial and upgrading/converting as I go to 2019.1 and this new version of the dpu core.
jasonwu
Hi @clutch12 ,
Yes, you are right. The files mentioned in DPU is a little out of date. I would suggest you to use the files inside the DPU TRD 2019.1 instead.
Main page: https://www.xilinx.com/products/design-tools/ai-inference/ai-developer-hub.html
Image download file: https://www.xilinx.com/member/forms/download/design-license-xef.html?filename=zcu102-dpu-trd-2019-1-190809.zip
And I am afraid that I am not sure the roadmap of the futurerelease. For now I would just suggest you to use custom files inside the latest DPU TRD release project.
Best Regards,
Jason
