noah98
vai_c_caffe fails to compile Reshape Layer
I am currently trying to compile a PointNet Caffe Implementation, but bumping in the Error that the vai_c_caffe fails to compile Reshape Layer. Can somebody hint me into the right direction? I probably have to Reshape my Data and remove the Reshape Layer, but lacking knowledge how to replicate the Reshape Layer behavior.
The Reshape Layer looks like that:
layer {
    type: "Reshape"
    bottom: "data"
    top: "data_reshape"
    reshape_param {
      shape {
        dim: 0  # copy the dimension from below
        dim: 1
        dim: -1
        dim: 3 # infer it from the other dimensions
thank you in advance.
graces
Reshape layer is not supported by the VAI_C. You may want to remove Reshape layer from the prototxt and use CPU to process this layer.
noah98
Thank you for your replay. Unfortunately I am still a novice. Do you know where to find an example how to do this step?
