vai_q_pytorch quant_mode 1 export quant config failed
I am trying to quantize a model which has torch.nn.PixelShuffle().
During Quantization it reported error because of the presence of Pixel Shuffle
and hence I removed the Pixel shuffle layer during quantization.
With Quantization mode 1, the tool can generate Quantizable module but it is reporting error when exporting quant config
orkspace/SRHW$ python quantize.py
[NNDCT_NOTE]: Loading NNDCT kernels...
---------------------- Model Loaded  ----------------------
---------------------- Trace Started ----------------------
---------------------- End of trace ----------------------
---------------------- Start SRHW Quantization ----------------------
[NNDCT_NOTE]: Quantization calibration process start up...
[NNDCT_NOTE]: =>Parsing SRHW...
[NNDCT_NOTE]: =>Quantizable module is generated.(quantize_result/SRHW.py)
[NNDCT_NOTE]: =>Exporting quant config.(quantize_result/quant_info.json)
Traceback (most recent call last):
File "quantize.py", line 170, in <module>
dirc=args.data_dir,quant_mode=args.quant_mode,val=False)
File "quantize.py", line 130, in quantization
quantizer.export_quant_config()
File "/home/htic/.conda/envs/pytorch-xilinx/lib/python3.7/site-
packages/pytorch_nndct/quantization/torchquantizer.py", line 221, in
export_quant_config
self.organize_quant_pos()
packages/pytorch_nndct/quantization/torchquantizer.py", line 203, in
organize_quant_pos
(out_name, self.quant_config['blobs'][input_name][1]))
KeyError: None
Looking into the torchquantizer.py script
https://github.com/Xilinx/Vitis-AI/blob/master/Vitis-AI-Quantizer/vai_q_pytorch/pytorch_binding/pytorch_nndct/quantization/torchquantizer.py
in line 200 self.configer.quant_inputs() returns  None keyword
Why is this occuring?
How to resolve it?
I am waiting for a reply
Thanks in advance
Performing forward pass (evaluation) before exporting quant_config solved the issue
