aliarserim
vitis 2020.2 zedboard
I want to to make cnn applications with zedboard vivado 2020.2 with zedboard. But there is an example with vivado2019.2 exists. It gaves error in vivado 2020.2.
Also can I reach the vitis files(c or python) of cnn algorithms anywhere.
Thanks from now
linqiang
aliarserim
 dear linqiang when I attempted to apply the Resnet50, this example was designed for vivado 19.2 at least so it gaves error for vivado 2020.2 so I thought that if I reach the vivado bd so I can design it for 2020.2.
davidxu
Hi @aliarserim
If you want to get the zedboard example design of vivado 2020.2,  you can refer to http://www.zedboard.org/
@linqiang
aliarserim
I dealed with zedboard community but they said that they had't any support about this subject
Also zedboard with resnet 50 is a reply as AR73058 # LFAR: Porting Resnet-50 CNN to zedboard, written by Antonello Di Fresco and Giovanni Guasti.
My problem is
this vivado project is formed by using vivado 2019.2 but I have installed vivado 2020.2. I try to open this bd in 2020.2 but it gaves error. So if I reach the vivado project design I can also form the bd of the above in vivado 2020.2.
Thanks from now
davidxu
