savan_sanghavi
xilinx ai sdk
i am using following tool chain which is for dnnc-1.4.0 but i have the dpu-ip-1.3  version.
https://www.xilinx.com/member/forms/download/dnndk-eula-xef.html?filename=xlnx_dnndk_v3.0_190624.tar.gz
i am facing [DNNDK] DPU target version mismatch for kernel. kernel: mnist, instruction: v1.4.0, DPU IP: v1.3.0.
this error,so  can somebody provide tool chain for dnnc-1.3.0?
kjgreenwood
kjgreenwood
sorry - this was to provide you with the ip for DPU v1.4.0. If you want the toolchain for DPU v1.3.0, you need to get DNNDK v2.0.8. I haven't been able to find a download location for it.
savan_sanghavi
i have used dnnc from updated dnndk version and it also have the dnnc compiler-1.4
the sdsoc also have the compiler for the 1.4
https://www.xilinx.com/member/forms/download/dnndk-eula-xef.html?filename=xilinx_dnndk_v2.08_for_sdsoc_190214.tar.gz
after running the exucutable on the board i am facing following error still.
kjgreenwood
DNNDK v2.0.8 should have given you DPU v1.3.0 instructions. Are you certain that you built the appropriate DNNC-generated .elf file into your software application after running DNNDK?
kjgreenwood
You should also make sure that /usr/local/bin/dnnc points to dnnc-dpu1.3.x (where x = 0 or 7).
guo_bing
I have xlnx_dnndk_v2.08_1902.tar.gz on my PC. I can provide it if you want.
