RTX5000
xilinx_vai_board_package
Hi ,
When I follow the instruction as bellow, I can not find the xilinx_vai_board_package in /opt/vitis_ai/.
Run the following command to remote copy the package from host to ZCU102 board with IP address 192.168.0.10: scp -r /opt/vitis_ai/xilinx_vai_board_package root@192.168.0.10:~/
What's wrong with my env?
Thanks a lot!
jasonwu
Hi @RTX5000 ,
From the document you need to start up the docker image first, and find folder inside the docker image.
I am afraid that I don't have VAI 1.0 docker on my side.
And BTW for now we have released VAI 1.2. I would suggest you to try with the latest tools/document version.
Best Regards,
Jason
jasonwu
Hi @RTX5000 ,
Would you please point out where you find this command?
Best Regards,
Jason
RTX5000
jasonwu
Hi @RTX5000 ,
Best Regards,
Jason
RTX5000
Actually the document is outdated , did not match with current image file.
jasonwu
Yes, for a later tool chain you need to refer to the document in the same version.
Best Regards,
Jason
