yolov3_tiny_3l_model
Did anyone used the yolov3 tiny 3l model with Xilinx Darknet2Caffe flow? It is the yolov3 tiny 3l model, with 3 yolo output layers model, from darknet rather than the base yolov3 tiny model which only has 2 yolo output layers. Any issues, pointers, or recommendations? Luc
Luc Chouinard
FPGA Architect & AI Specialist
Teledyne Imaging
Teledyne Lumenera
Re: yolov3_tiny_3l_model
Was able to run the yolo tiny 3l (3 yolo output layers) model, same number of output layers as the full yolo model. It is a bit slower in term of FPS than the 2l (2 yolo output layers) as it is a bit deeper ie 28 layers vs 21 layers, but has better accuracy specially if you have object at different scales to recognize. Nothing specifically different to do beside having to identify the specific yolo output layers "names" during the darknet to caffe flow. This can be marked as SOLVED. Luc
Luc Chouinard
Teledyne Imaging
Teledyne Lumenera
Yolov3_tiny_3l should work with the Darknet2Caffe flow, but first you will need to make one modification to the .cfg file and retrain. There is a mismatch between how Darknet and Caffe handel max pooling layers of stride 1, which will cause a Caffe error. Tiny Yolov3 as well as Tiny Yolov3_3l both contain such a layer.
The solution is to comment out the layer in the .cfg file and retrain:
If you already have pretrained weights, you can probbaly load these in and then continue the training in Darknet rather than starting from scratch.
Once you convert to Caffe and quantize and compile with the DNNK tools, you can then use the Yolov3 sw examples in AI SDK install. See the following post on how to use a custom Yolov3 model with the AI SDK Yolo examples:
https://forums.xilinx.com/t5/Machine-Learning/Using-custom-models-with-AI-SDK-v2-0-5-sw-samples/m-p/1011156#M1979v3
If you follow the instructions in that post, one of the things that you will do is to create a DPU prototext file that is used by the AI SDK post processing library.
If you are doing letterboxing of the input images, then make sure the line is_tf line is set to true (Example for Tiny Yolov3 below)
I have created a Tutorial on how to use Tiny Yolov3 with the AI SDK examples.  The process for Tiny Yolov3_3l should be almost identical.  The tutorial is not relased yet, but contact me if you want it and I can send it to you.
Luc Chouinard
Teledyne Imaging
Teledyne Lumenera
