AXI VIP Usage
Dear Forum,
Please help to use AXI VIP in my design.
So based on users doc to user AXI VIP I need to
1) import <component_name>_pkg
2) declare agent
3) start agent
However when I import the <component_name>_pkg, vivado gives elaboration error. It is not able to find the imported package.
And this is the error:
Please help to use AXI VIP. I also reviewed the AXI VIP example design, in that design instate of <component_name>_pkg the <instance_name>_pkg is imported,
and agent was created by <instance_name>_mst_t agent statement. So is this right?
I have tried with this way i.e. used <instance_name> instead of <component_name> than the agent calling gives error.
H
Any updates on this?
Hi @hayk.petr
I do not know if you have solved your problem yet.
It seems you have done correctly in the code, but I am suspicious that if you configured your AXI VIP properly in your block design.
I had such a problem before.
Amir
Hi @hayk.petr
The line is incorrect:
import axi_vip_0_pkg::;
It should be
import design_1_axi_vip_0_1_pkg::;
The package for your second instance of the AXI VIP should be like this:
import design_1_axi_vip_0_2_pkg::;
Deanna
@demarco thanks for the answer
Please take a look on pg267, page 48, where is written that component_name is master name and not instance name.
But your suggestion worked.
