Visitor andrea96b
AXI custom IP with interrupt support
Hi, I have a problem understanding how the axi interrupt support work.
I have a uart like IP that generate 2 interrupt, one when a signal named RDA is high, and one when a signal named TBE has a rising edge.
I have modified the generated interrupt support file like this.
Section where I've added the logic of interrupt generation.
	process( S_AXI_ACLK ) is
	  begin
	    if (rising_edge (S_AXI_ACLK)) then
	      if ( S_AXI_ARESETN = '0') then
	        intr <= (others => '0');
	      else
	          intr <= RDA & TBE;
	      end if;
	    end if;
	end process;
Configuration parameters
		-- Width of S_AXI data bus
		C_S_AXI_DATA_WIDTH	: integer	:= 32;
		-- Width of S_AXI address bus
		C_S_AXI_ADDR_WIDTH	: integer	:= 5;
		-- Number of Interrupts
		C_NUM_OF_INTR	: integer	:= 2;
		-- Each bit corresponds to Sensitivity of interrupt :  0 - EDGE, 1 - LEVEL
		C_INTR_SENSITIVITY	: std_logic_vector	:= x"FFFFFFFE";
		-- Each bit corresponds to Sub-type of INTR: [0 - FALLING_EDGE, 1 - RISING_EDGE : if C_INTR_SENSITIVITY is EDGE(0)] and [ 0 - LEVEL_LOW, 1 - LEVEL_LOW : if C_INTR_SENSITIVITY is LEVEL(1) ]
		C_INTR_ACTIVE_STATE	: std_logic_vector	:= x"FFFFFFFF";
		-- Sensitivity of IRQ: 0 - EDGE, 1 - LEVEL
		C_IRQ_SENSITIVITY	: integer	:= 1;
		-- Sub-type of IRQ: [0 - FALLING_EDGE, 1 - RISING_EDGE : if C_IRQ_SENSITIVITY is EDGE(0)] and [ 0 - LEVEL_LOW, 1 - LEVEL_LOW : if C_IRQ_SENSITIVITY is LEVEL(1) ]
		C_IRQ_ACTIVE_STATE	: integer	:= 1
The problem is that the interrupt for the signal TBE seems to be generated as it were level interrupt instead of edge triggered. I've also created a testbench where to be sure I've setted all the interrupt to edge triggered.
The irq signal rise up immediately when I enable the interrupt without any rising edge.
Tags (3)
Scholar dgisselq
Re: AXI custom IP with interrupt support
I must be missing something.  I tried to recreate your results, and just got errors about how the `s_irq` net is being driven by constants from multiple places.
