AXI traffic generator Basic mode example design
Dear Forum,
I am trying to understand AXI traffic generator Basic mode, by analyzing example design.
In the example design the traffic generator is being configured by S_AXI port, and this is the waveform:
Can you please help understand what addresses are: 00008000, 00008004, 00008008, 0000800c, 00009000, 00009004, 00009008,….
I was expecting that the programming sequence would be like in users doc “Advanced/Basic Mode with Processor” section of “Programing Sequence”. However seems no.
Can someone please explain these waves and the AXI basic mode configuration flow.
Hayk
Any updates on this? this is really urgent case
Hi @hayk.petr
This is Gareth and I moderate the AXI Infrastructure board. I am sorry that this was not picked up and I will address this in the future.
I am not an expert on the AXI TG IP but I have taking a look at the documentation and I would like to understand more what is the misunderstanding. From my understanding in Advanced/Basic there is a CMDRAM/MSTRAM write and read transaction. See below:
PG125 Page 71PG125 Page 71
Now looking at the Address Map I can see that the CMDRAM address range is located at 0x00008000 to 0x00009FFF and the MSTRAM is 0x0000C000 to 0x0000DFFF.
In your waveform you can see the s_axi_awaddr is 0x00008000 which would be a write to the CMDRAM and then 0x000C000 which is a write to the MSTRAM.
PG125 Page 20PG125 Page 20
Please let me know if I have missed something and we can continue this discussion.
Kind regards,
Gareth
@agar_ Thanks for the answer
Yes your are right, after many tries we come to the same conclusion~ thanks for the answer
