lucaj88
Help with IP integrator Axi stream for Matrices Multiplication
I want to test on a Pynq the matrix multiplication example provide in HLS.
I just made some changes, in particular I enable AXI interface for input and output and a pragma to pipeline functions and the testbench exit with no errors.
void matrix_multiply_top(const MATRIX_T A [A_ROWS][A_COLS],
                    const MATRIX_T B [B_ROWS][B_COLS],
                    MATRIX_T C[C_ROWS][C_COLS]){
#pragma HLS INTERFACE axis port=A
#pragma HLS INTERFACE axis port=B
#pragma HLS INTERFACE axis port=C
#pragma HLS INTERFACE s_axilite port=return
#pragma HLS PIPELINE II=1
The block design is built according to the pdf attached.
The synthesis and the implementation ends without issues and let me to download the bitstream.
When I try to use it in pynq notebook, the DMA transfer seems in a deadlock state:
dma0 = overlay.axi_dma_0
dma1 = overlay.axi_dma_1
from pynq import Xlnk
import numpy as np
xlnk = Xlnk()
in_buffer0 = xlnk.cma_array(shape=(5,), dtype=np.uint32)
in_buffer1 = xlnk.cma_array(shape=(5,), dtype=np.uint32)
out_buffer = xlnk.cma_array(shape=(1,), dtype=np.uint32)
dma0.sendchannel.transfer(in_buffer0)
dma1.sendchannel.transfer(in_buffer1)
dma0.sendchannel.wait()
dma1.sendchannel.wait()
And the execution stucks here.
Can I assume that the HLS implementation of the is correct since testbench exit without error?
In this case the problem lays in the block design or in Pynq execution?
Can you suggest some reference for building accurate and efficient block design?
Thank you,
Luca
demarco
Hi @lucaj88 ,
I'm not a Phython expert, but don't you need to do something to set up the receive channel on dma0? I don't see out_buffer getting used anywhere in your code.
Deanna
lucaj88
Yes, it should but anyway is stucked on sending stage.
demarco
Hi @lucaj88 ,
Depending on how your HLS IP works, you may not be able to receive data on the inbound path until your outbound path is primed to receive more data. The AXI DMA can store a few dwords of data on the S2MM path without configuration, but after that is will drop TREADY. This could potentially stall your system.
Besides, it's generally good coding practice to set up your receive path before enabling the transmit path.
Please add the necessary code to enable the DMA0 receive channel.
Deanna
