ps dma
Hello Zynq masters,
                  I hope to use Ps DMA to move data  from one part  of DDR  to another part  of DDR .we need do this  operation  on  SDK  plateform .  But  i can't   write   specific registers  for  DMA.  Can you tell me how to do  ?
Hi @yqq654101,
Your problem description is pretty vague. How are you attempting to access the registers in the PS DMA? How do you know the writes aren't working?
A good place to start is to review the bare metal examples for using the PS DMA (also called ZDMA) that are available in SDK. Once you import your design and create the BSP, the system.mss file has links to import the examples.
You can also access the source on Github.
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/zdma/examples
Deanna
ok,thank your solution . I have solved the problem.
