Visitor josh97
AXI DMA data width for color images
I have an IP block design for a project that looks like this:IP_blocks.pngIP Blocks
 I have a video processing block which takes its input from the DMA's MM2S port, and whose output is fed to the DMA's S2MM port. I am dealing with color images inside the video processing block, and so I had defined pixels to be of 24 bits (8x3) size while defining my axi stream within the block (using Vivado HLS) like this:
typedef hls::stream<ap_axiu<24,1,1,1>> AXI_IN_STREAM;
However, when I tried to validate the design, Vivado throws the following errors:Error.pngErrors while validating
 Both errors are because the AXI DMA core only allows stream widths of 8, 16, 32, 64 etc bits and the current setting is 32 bits. I could not find 24 bits in the drop-down menu.
AXI_DMA.pngAXI DMA stream width drop down menu
Is there any way I can work around this? I need only 3 bytes (24 bits) for my colour images, but the AXI DMA only allows 8, 16, 32 etc. bits for the stream widths.
Re: AXI DMA data width for color images
Hi @josh97,
There is a DMA for Video called the Video DMA (refer to PG020). It allows a stream of 24 bits. This is better than just a workaround ;)
Florent
Hi @josh97,
Florent
Visitor josh97
Thanks!
