Newbie va_anh
AXI FULL
I createed a neu  IP using the AXI 4 FULL bus in master. I want to create 2 task(read/write) using the axi bus in master to perim read and write addr and data. Show me how to write 2 task to read and write addr and data.
Re: AXI FULL
Hi @va_anh,
In vivado, you can create an AXI peripheral which contains template for the AXI interface. You might want to refer to the following quick take video:
https://www.xilinx.com/video/hardware/creating-an-axi-peripheral-in-vivado.html
