AXI IPIF Problem
               In my project i need to add my custom logic into Block Diagram which is controlled by Zynq ARM . So i need to add AXI-Lite signal to configure my custom logic register. I searched the AXI IPIF IP topic in xilinx forums. but i don't known how to use it as well as which is a hidden IP. So my question is
What are the procedure to use IPIF and how to add my custom logic into IPIF.
There are procedure for How to Create and Package IP in the Vivado. But I need IPIF based configuration. I am using Vivado 2018.1.
kannan
Scholar jg_bds
Re: AXI IPIF Problem
In the Vivado menu bar, select "Tools" -> "Create and Package New IP...":
Choose "Create AXI4 Peripheral":
Configure the peripheral to contain the AXI-Lite interface(s) that you need:
Once the tool creates the framework files, update them with your custom logic.
After updating the HDL files, repackage the IP so you can place it in a Vivado IPI block diagram.
If you haven't already done so, get a copy of the AXI spec:
https://developer.arm.com/products/architecture/system-architectures/amba/amba-4
-Joe G.
                Thank you for your response. but i want to use IPIF in my project.
kannan
Scholar jg_bds
Hi @kannan
The following AR provided files for the deprecated AXI IPIF helper IPs.
AR:62549 - https://www.xilinx.com/support/answers/62549.html
Kind regards,
Gareth
