Visitor uuoo93
[AXI4-Stream subset converter : Extra Setting problem]
Hell. I am working on ZCU102 evaluation board and Vivado HLx system suite version 2018.2.(Window O.S) I used AXI4-Stream subset converter v1.1, but there is a problem.
According to PG085 document(AXI4-Stream Infrastructure IP Suite v1), constant elements can be used.
< PG085 version 1.0, page 47>
However, I can’t use constant elements as shown in figure1. Constant elements are unsupported syntax as shown in figure2.
<figure 1>
<figure2 >
How can I solve this problem?
Re: [AXI4-Stream subset converter : Extra Setting problem]
Hi @uuoo93,
The syntax is a bit wrong in the pg085, the apostrophe is missing before the b
you need to use 4'b0000. You can refer to the TID or TKPEEP lines for reference.
Hi @uuoo93,
Visitor uuoo93
Thank you!!
