Customize AXI GPIO IP.
I'm new to Zynq and I'm trying to connect some IOs push buttons and LEDs in PL using a AXI Lite port. These IOs are assigned different addresses. Since AXI Lite has both write and read channels, I suppose the port should be both readable and writeable.
I followed Getting Started with Zynq, in which the ports are initialized with XGpio_Initialize() and XGpio_SetDataDirection(). It seems the port has to be either readable or writeable, not simultaneously.
So my question is:
Are XGpio_Initialize() and XGpio_SetDataDirection() the standard functions used to initialize a GPIO port? If yes, how to configure the port for read and write? If no, what else can I?
Or, did I misunderstand something?
Thank you.
Re: Customize AXI GPIO IP.
Hi @fiedel ,
Please refer the below user guide for the example design of configuring the GPIO(Design 1)
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug1209-embedded-design-tutorial.pdf
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
