How to write XSDK code for AXI performance monitor for Zynq UltraScale MPSoC [ZCU102]
How to write the XSDK code to program the AXI performance monitor core for event counting and event logging in advanced mode.
In AXI performance monitor, I have used Axi streaming interface in advanced mode.
I have followed the APM documentation https://www.xilinx.com/support/documentation/ip_documentation/axi_perf_mon/v5_0/pg037_axi_perf_mon.pdf
Through the APM documentation, i have tried the below code, but result`s are printing Zero`s. Please anyone guide me.
#include <stdio.h>
#include <stdlib.h>
#include "xaxipmon.h"
#include "xil_cache.h"
#define AXIPMON_DEVICE_ID_0		XPAR_AXIPMON_0_DEVICE_ID
#define AXIPMON_DEVICE_ID_1		XPAR_AXIPMON_1_DEVICE_ID
static XAxiPmon monitor;
static XAxiPmon monitor1;
void initpmon()
	XAxiPmon_Config *ConfigPtr;
	XAxiPmon_Config *ConfigPtr1;
	u32 Status;
	  /* Initialize the Device Configuration Interface driver */
	ConfigPtr = XAxiPmon_LookupConfig(AXIPMON_DEVICE_ID_0);
	if (ConfigPtr == NULL) {
		return XST_FAILURE;
	Status = XAxiPmon_CfgInitialize(&monitor, ConfigPtr, ConfigPtr->BaseAddress);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	ConfigPtr1 = XAxiPmon_LookupConfig(AXIPMON_DEVICE_ID_1);
		if (ConfigPtr1 == NULL) {
			return XST_FAILURE;
		Status = XAxiPmon_CfgInitialize(&monitor1, ConfigPtr1, ConfigPtr1->BaseAddress);
			return XST_FAILURE;
	// Enable Metric Counters
	XAxiPmon_EnableMetricsCounter(&monitor);
	// Set Sample Interval
	XAxiPmon_SetSampleInterval(&monitor, 400000000); // Equals 2 second
	xil_printf("Initialized pmon\r\n");
void readpmon()
	u32 Intr;
	// Reset Metric Counters
	XAxiPmon_ResetMetricCounter(&monitor);
	// Load Sample Interval Counter and start Countdown
	XAxiPmon_LoadSampleIntervalCounter(&monitor);
	XAxiPmon_EnableSampleIntervalCounter(&monitor);
	// Poll Sample Interval Counter Overflow Interrupt Bit
	while ((Intr & XAPM_IXR_SIC_OVERFLOW_MASK) == 0)
		Intr = XAxiPmon_IntrGetStatus(&monitor);
	//XAxiPmon_DisableMetricsCounter(&monitor);
	// Clear Sample Interval Counter Overflow Interrupt Bit
	XAxiPmon_IntrClear(&monitor, XAPM_IXR_SIC_OVERFLOW_MASK);
	// Read out Metric Counters
	u32 ReadByteCount = XAxiPmon_GetSampledMetricCounter(&monitor, XAPM_METRIC_COUNTER_3);
	u32 WriteByteCount = XAxiPmon_GetMetricCounter(&monitor, XAPM_METRIC_COUNTER_0);
	xil_printf("Read byte count HP0 = %d per sec\r\n", ReadByteCount/2);
	xil_printf("Write byte count HP0 = %d per sec\r\n", WriteByteCount/2);
	ReadByteCount = XAxiPmon_GetSampledMetricCounter(&monitor, XAPM_METRIC_COUNTER_9);
	WriteByteCount = XAxiPmon_GetMetricCounter(&monitor, XAPM_METRIC_COUNTER_6);
	xil_printf("Read byte count HP1 = %d per sec\r\n", ReadByteCount/2);
	xil_printf("Write byte count HP1 = %d per sec\r\n", WriteByteCount/2);
int main()
	xil_printf("Hello");
	initpmon();
	while(1)
		getchar();
		readpmon();
Re: How to write XSDK code for AXI performance monitor for Zynq UltraScale MPSoC [ZCU102]
Hi @thaus_015,
You mentioned that the Performance Monitor is in Advance Mode. I'm not seeing where you set up the metrics for any counters in the initpmon() function. I'd expect to see a few calls to XAxiPmon_SetMetrics.
Your initialization sequence should look pretty similar to this example:
https://github.com/Xilinx/embeddedsw/blob/master/XilinxProcessorIPLib/drivers/axipmon/examples/xaxipmon_polled_example.c
Deanna
