Issue in example code of cyclic mode + AXI DMA ??
     In the xaxidma_example_sgcyclic_intr.c,
The cyclic mode setup of TxDMA [MM2S] does NOT follow the [AXI DMA v7.1 14 PG021 April 4, 2018]
"This bit should be set/unset only when the DMA is idle or when not running. Updating this bit while the DMA is running can result
in unexpected behavior."
https://github.com/Xilinx/embeddedsw/blob/b2f54f649486ec1435f2f6b6e524d9c9c84f2efc/XilinxProcessorIPLib/drivers/axidma/examples/xaxidma_example_sgcyclic_intr.c
Code: -
in Txsetup(), the DMA engine is started
in TxSetup() --> XAxiDma_BdRingStart() --> XAxiDma_StartBdRingHw() --> the bit of XAXIDMA_CR_RUNSTOP_MASK is set in this function
and in SendPacket() [a much later function in the code flow], the bit of XAXIDMA_CR_CYCLIC_MASK is set in
XAxiDma_SelectCyclicMode()
This goes against the Xilinx official document.
Re: Issue in example code of cyclic mode + AXI DMA ??
Hi @optivareddy,
The AXI DMA is idle when the cyclic mode bit is set in SendPacket().
You can verify this by reading MM2S_DMASR when you hit the SendPacket() break point. If bit 1 is set to 1, the channel is idle and it is okay to set the cyclic mode bit.
Deanna
    memory dump at breakpoint at SendPacket() call.
mrd -force 0xA0260000 20
A0260000: 640A7003 <-------[MM2S_DMACR]
A0260004: 000A0008 <-------[MM2S_DMASR]
000A0008 [MM2S_DMASR]
binary representation 0000 0000 0000 1010 0000 0000 0000 1000
bit 0 value : - 0
bit 1 value : - 0
//==========================//From Xilinx doc
Bit 0:
DMA Channel Halted. Indicates the run/stop state of the DMA
channel.
0 = DMA channel running.
• 1 = DMA channel halted.
Bit 1:-
0 = Not Idle.
• 1 = Idle.
bit 0 says DMA channel running and bit 1 says DMA channel Not idle.
please let me know your re-take on this.
