Visitor cannadya1
Question regarding axi_UART FIFO and register addressing
Hello, I just had a few quick questions.
When a "character" is stored in the axi_uartlite FIFO, is this character stored as an unsigned integer? In our case it's a 8-bit message, so is each character stored as a value from 0 to 255?
If within this character, there is a parity bit error, would this message still get transmitted/received?
In regards to address,
The uart is given a base address automatically within vivado. In my case, 0x42C0_0000 to 0x42C0_FFFF. Would each Tx and Tx message be stored in this range by some offset?
Is the offset different for each message, or is it a standard offset?
Does this relate to FIFO memory at all?
Scholar jmcclusk
Re: Question regarding axi_UART FIFO and register addressing
It's all explained here:
https://www.xilinx.com/support/documentation/ip_documentation/axi_uartlite/v2_0/pg142-axi-uartlite.pdf
You can't randomly access the TX or RX messages, only write or read them sequentially, one byte at at time.   From what I can tell, a parity error on reception sets a flag (or can generate an interrupt), but it's not saved in the RX Fifo.
Visitor cannadya1
Hi, thanks for the response!
Quick question, when you say "but it's not saved in the RX FIFO" do you mean the flag/interrupt is not saved in the RC FIFO, or that the message is not saved?
Scholar jmcclusk
A parity error generates a status bit, but you can't tell which character actually had the parity error.   The fifo only holds 8 bits of data, and nothing about parity errors.
