S2MM AXI DMA Simple Mode problem
Hi all,
My userspace application for simple mode AXI DMA , freezes while polling status register, although MM2S works perfectly.
here is my code , please help me to figure out :
#include <stdio.h>
#include <unistd.h>
#include <fcntl.h>
#include <termios.h>
#include <sys/mman.h>
#include <string.h>
#include <stdlib.h>
#define DMA_BASE_ADDRESS 	 0xa0000000
#define MM2S_CONTROL_REGISTER 	 0x00
#define MM2S_STATUS_REGISTER     0x04
#define MM2S_SOURCE_ADDRESS      0x18
#define MM2S_LENGTH 	         0x28
#define S2MM_CONTROL_REGISTER 	 0x30
#define S2MM_STATUS_REGISTER 	 0x34
#define S2MM_DESTINATION_ADDRESS 0x48
#define S2MM_LENGTH 		 0x58
#define DESTINATION_ADDRESS     0X80001400
#define SOURCE_ADDRESS		0x80001C00
static volatile unsigned int* dma_virt_addr=NULL;
static volatile unsigned int* virt_source_buf_address=NULL;
static volatile unsigned int* virt_destination_buf_address=NULL;
unsigned long page_size;
int main () {
int fd = open("/dev/mem", O_RDWR | O_SYNC);
if (fd<0) {
perror("\nError opening device file\n");
page_size=sysconf(_SC_PAGE_SIZE);
dma_virt_addr=(unsigned int*)mmap(DMA_BASE_ADDRESS, 65535, PROT_READ | PROT_WRITE, MAP_SHARED, fd, page_size);
if (dma_virt_addr == NULL) {
printf("\nUnable fetch virt. addr. for AXI DMA\n");
virt_source_buf_address=(unsigned int*)mmap(SOURCE_ADDRESS, 256*1024, PROT_READ | PROT_WRITE, MAP_SHARED, fd, page_size);
if (virt_source_buf_address == NULL) {
perror("\nUnable fetch virt. addr. for AXI DMA buffer\n");
virt_destination_buf_address=(unsigned int*)mmap(DESTINATION_ADDRESS, 256*1024, PROT_READ | PROT_WRITE, MAP_SHARED, fd, page_size);
if (virt_destination_buf_address== NULL) {
//WRITE SOURCE AND DESTINATION ADDRESSES FOR TX(MM2S) AND RX (S2MM)
///////////////////////////////////WRITING DMA -MM2S///////////////////////////////////////////////////////////////////
//userspace_source_buffer_allocation
 unsigned int* src_buff;
 src_buff=(unsigned int*) malloc(1024);
//fill in the userspace_buffer locations with some random data
int i;
for( i=0; i<1024/4; i++){
*src_buff=i+1;
//#DEBUG
printf("userspace buffer data\n%d",*src_buff);
src_buff++;
//memset(virt_source_buf_address,25,10);
//copy datafrom userspace buffer tovirtual buffer to be sent
memcpy(virt_source_buf_address,src_buff,1024);
//start data transfer (Write) data to DMA(MM2S)
*(dma_virt_addr+MM2S_CONTROL_REGISTER)=0x801;
*(dma_virt_addr+MM2S_SOURCE_ADDRESS)=SOURCE_ADDRESS;
*(dma_virt_addr+MM2S_LENGTH)=1024;
while ((*(dma_virt_addr+ MM2S_STATUS_REGISTER) & (0x1<<12)) == 0);
printf("\nTransfer complete\n%h\n",*(dma_virt_addr+ MM2S_STATUS_REGISTER));
///////////////////////////////////////READING DMA -S2MM///////////////////////////////////////////////////////////////////
//userspace destination buffer allocation
unsigned int* dest_buff;
dest_buff=(unsigned int*)malloc(1024);
memset(dest_buff,0,1024);
//start data transfer (Read) data from DMA (S2MM)
*(dma_virt_addr+S2MM_CONTROL_REGISTER)=0x801;
*(dma_virt_addr+S2MM_DESTINATION_ADDRESS)=DESTINATION_ADDRESS;
*(dma_virt_addr+S2MM_LENGTH)=1024;
printf("S2MM statuc\n%h\n",*(dma_virt_addr+S2MM_CONTROL_REGISTER));
//while ((*(dma_virt_addr+ S2MM_STATUS_REGISTER) & (0x1<<12)) == 0);
printf("\nReading complete from DMA S2MM\n");
//copy data read from DMA back to user space buffer
memcpy(dest_buff,virt_destination_buf_address, 1024);
//Verify the Test Results
int j;
for (j=0; j<1024/4; j++) {
printf("\data read\n\n%d",*dest_buff);
dest_buff++;
return 0;
Re: S2MM AXI DMA Simple Mode problem
Hi @haroonrl123,
I think the problem is in this line:
Your code does not enable the IOC_IrqEn bit in the MM2S_DMACR register. It is bit 12 and you are enabling bit 11. You need to enable this bit in order for polling on the interrupt in the MM2S_DMASR register to work.
Deanna
Thanks for your reply. i changed the values, but still it's not working . Kernel freezes.
then i build kernel module and what i figured out that the problem is with writing to DDR memory via virtual address returned by ioremap_nocache() function i used.
here is my kernel module i wrote to test :
#include <linux/delay.h>
#include <linux/dmaengine.h>
#include <linux/init.h>
#include <linux/kthread.h>
#include <linux/module.h>
#include <linux/random.h>
#include <linux/slab.h>
#include <linux/wait.h>
#include <linux/version.h>
#include <linux/interrupt.h>
#include <linux/vmalloc.h>
#include <linux/mman.h>
#include <linux/types.h>
#include <linux/fs.h>
#include <linux/errno.h>
#include <linux/mm.h>
#include <linux/sched.h>
#include <linux/cdev.h>
#include <linux/kernel.h>
#include <asm/io.h>
#include <asm/uaccess.h>
#include <asm/cacheflush.h>
#define DEVICE_NAME   "dma_kernel"
#define CLASS_NAME    "axi_dma"
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Harry");
MODULE_DESCRIPTION("A simple Linux driver for the AXI DMA.");
MODULE_VERSION("1.0");
//static void __iomem *dma_virt_addr;
static void __iomem *virt_source_buf_address;
//static void __iomem *virt_destination_buf_address;
//static unsigned int* p;
//static volatile unsigned int* dma_virt_addr;
static int    majorNumber;
static struct class*  axidmaclass  = NULL;
static int     axi_dma_open(struct inode *, struct file *);
static int     axi_dma_release(struct inode *, struct file *);
static int axi_dma_open(struct inode *inodep, struct file *filep){
   printk(KERN_INFO "AXI DMA: Device has been opened time(s)\n");
   return 0;
static int axi_dma_release(struct inode *inodep, struct file *filep){
   printk(KERN_INFO "AXI DMA: Device successfully closed\n");
   return 0;
static struct file_operations axi_dma={
.owner=THIS_MODULE,
.open=axi_dma_open,
.release=axi_dma_release,
static int __init axi_dma_init(void){
// Try to dynamically allocate a major number for the device -- more difficult but worth it
   majorNumber = register_chrdev(0, DEVICE_NAME, &axi_dma);
   if (majorNumber<0){
      printk(KERN_ALERT "axidma failed to register a major number\n");
      return majorNumber;
   printk(KERN_INFO "axidma: registered correctly with major number %d\n", majorNumber);
   // Register the device class
   axidmaclass = class_create(THIS_MODULE, CLASS_NAME);
   if (IS_ERR(axidmaclass)){                // Check for error and clean up if there is
      unregister_chrdev(majorNumber, DEVICE_NAME);
      printk(KERN_ALERT "Failed to register device class\n");
      return PTR_ERR(axidmaclass);          // Correct way to return an error on a pointer
   printk(KERN_INFO "axidma: device class registered correctly\n");
//request memory region
if(request_mem_region(0x80001400,256*2048,"axi_dma_mmeory")==NULL){
printk("failed to request memory region\n");
   printk(KERN_INFO "AXI DMA Initialized");
	u32  *src_buffer;
	u32  *dest_buffer;
	u32  *p;
	src_buffer = kmalloc(1024, GFP_KERNEL);
	dest_buffer = kzalloc(1024, GFP_KERNEL);
int i;
if (!src_buffer || !dest_buffer) {
		printk(KERN_ERR "Allocating memory failed\n");
		return -1;
		for (i = 0; i < 1024/4; i++)
		src_buffer[i] = i;
	virt_source_buf_address = ioremap_nocache(0x80001400, 256*1024);
        if (!virt_source_buf_address ) {
                printk("Could not map physical memory to virtual\n");
                return -1;
	printk("virt_source_buf_address: %08X\n", (unsigned int)virt_source_buf_address);
	p = virt_source_buf_address;
		for (i = 0; i < 1024/4; i++){
		__raw_writel(src_buffer[i], p++);
			printk("data \n%d\n",*p);
			*p++;
		dest_buffer[i] = __raw_readl(p++);
		for (i = 0; i < 1024/4; i++) {
		if (dest_buffer[i] != src_buffer[i]) {
			printk("index = %d, src=%02X, dest = %02X\n", i, src_buffer[i], dest_buffer[i]);
return 0;
static void __exit axi_dma_exit(void){
	device_destroy(axidmaclass, MKDEV(majorNumber, 0));     // remove the device
   	class_unregister(axidmaclass);                          // unregister the device class
   	class_destroy(axidmaclass);                             // remove the device class
   	unregister_chrdev(majorNumber, DEVICE_NAME);             // unregister the major num
	release_mem_region(0x80001300 ,256*1024*256);
        printk(KERN_INFO "AXI DMA Exit\n");
module_init(axi_dma_init);
module_exit(axi_dma_exit);
when i insert the module kernel hangs /stucks/freezes with following results:
i have been struggling to figure out this problem since two weeks, please help me out , this project is really important to me.
Visitor yedechang
你好,我现在也遇到了这个问题请问您是怎么解决的?非常期待您的答复!!!!!
@yedechang, please ask the question in Chinese forum http://forum.xilinx.com/cn if you need to use Chinese. Thanks for your co-operation.
Visitor yedechang
Hello, I have encountered this problem now. How do you solve it? I look forward to your reply!!!!!
