Participant eldrick
Stalls in Cyclic DMA to JESD204B TX
I'm currently running an AXI DMA from PL DDR4 to a JESD204B IP Core configured for TX with an output of 245.76 MSPS (LMFS = 2441). My DMA is set up with Scatter-Gather in Cyclic Mode - in essence I'm transferring a signal stored in DDR4 in a looping manner. The signal output of my DAC (TI DAC38J84) however shows a few stalls between chunks of valid data that I suspect may be originating from the DMA. In my screen shots below, I seem to get 7.5 us of continuous data and a short 320-340 ns stall in between the chunks. What could be causing this stall in the output stream?
Participant eldrick
Re: Stalls in Cyclic DMA to JESD204B TX
Participant eldrick
