Visitor jesuabi.lc
Use AXI DMA to read on-chip RAM in RedPitaya V1.1
HI everyone
I've been asked to use a RedPitaya system to read data from a file and send it out trough the digital I/O on my board as a digital sequence.
I wrote a C code, and put some IP blocks together on Vivado, wrote a file with random 32 bit values and run all the system together with Linux using Putty. The results were...expected but disapointing, the sequences got out correctly from the digital I/O...but pretty slowly, at a 100 khz frequency.
Before that I was able to pull out  4 digital sequences at full clock speed (125 Mhz), writing 4 registers manually, and using a shift register code I wrote on VHDL.
I'm using an AXI_GPIO to write the values that my C code reads from the SD card, I've been reading about using AXI DMA, but I don't really understad how does it works.
My idea now is to read the values from SD card, write them on the RAM and then send it directly to the PL
Here is my Block Diagram and my C code for you tu analyze
And here is my C code:
#include <stdio.h>
#include <stdint.h>
#include <unistd.h>
#include <sys/mman.h>
#include <fcntl.h>
#include <string.h>
#include <stdlib.h>
int main(int argc, char **argv)
  int fd;
  long N_val=0;
  void *cfg;
  char *name = "/dev/mem";
  char filename[30];
  if (argc == 2)
  		strcpy(filename,argv[1]);
  		printf("abriendo ''%s''...\n",filename);
  else
 		printf("Número de argumentos erroneos");
 		return 0;
  if((fd = open(name, O_RDWR)) < 0)
    	perror("open");
    	return 1;
  cfg = mmap(0, sysconf(_SC_PAGESIZE), PROT_READ|PROT_WRITE, MAP_SHARED, fd, 0x42000000);
  FILE *file=fopen(filename,"r");
  if ( file != NULL )
      	char line [ 65535 ]; /* or other suitable maximum line size */
	      while ( fgets ( line, sizeof line, file ) != NULL ) /* read a line */
	         *((uint16_t *)(cfg)) = atof(line);
	    N_val=N_val++;
	    fclose ( file );
  else
      	perror ( filename ); /* why didn't the file open? */
  printf("Numero de valores: %li\n", N_val);
  *((uint16_t *)(cfg)) = 0;
  munmap(cfg, sysconf(_SC_PAGESIZE));
  return 0;
Re: Use AXI DMA to read on-chip RAM in RedPitaya V1.1
Hi @jesuabi.lc,
I'm not sure what your question is. It sounds like you are interested in using AXI DMA, so I thought I would point out a few resources to get started.
The Product Guide is here:
https://www.xilinx.com/products/intellectual-property/axi_dma.html
Example code and bare metal drivers are here:
https://github.com/Xilinx/embeddedsw/tree/master/XilinxProcessorIPLib/drivers/axidma
Deanna
Visitor jesuabi.lc
Hi Demarco
I wonder if someone could help me improve my current desing using AXI_DMA, because I really don't know what to do about the data transfer between my RedPitaya's SD Card, the DDR memory, the PS and the PL.
Thanks for the documentation, but I'm really new at all this SoC things.
