Visitor olkhramus
*ZYNQ_MPSoC_BFM_ERROR : M_AXI_GP1 : Port is disabled.
During Simulation I got an error message :
M_AXI_HPM1_FPD : *ZYNQ_MPSoC_BFM_INFO : Starting Address(0xb0000000) -> AXI Write -> 4 bytes
*ZYNQ_MPSoC_BFM_ERROR : M_AXI_GP1 : Port is disabled. 'write_data' will not be executed...
How to enable M_AXI_GP1 port? Is it related to the PMU block?
Re: *ZYNQ_MPSoC_BFM_ERROR : M_AXI_GP1 : Port is disabled.
Hello @olkhramus
This looks like an issue with setting the ports properly on your Zynq PS PCW.  If you select your Zynq PS and go to the PS-PL Configuration page, then on PS-PL Interfaces > Master Interface you should be able to see the different Full-Power Domain and Low-Power Domain ports.  Do you see AXI HPM1 FPD checked?  If not, can you try simulating with that port checked.
Caleb
