ZYNQ Ultrascale+ and Axi Performance monitor
I want to measue real-time performance metrics for throughput and latency for connected AXI interfaces (i.e. Axi4 Stream interface). From the Axi Performance monitor user guide, i understood little bit but not completely.
Advance mode will support AXI4-Stream interface. But i don`t know the programming sequence in XSDK.
Through  some guide reference, i wrote below code to execute  real-time performance metrics measurement. But It`s not working. Any correction please suggest me or Any example design with programming sequence in XSDK. Please share to me.
static XAxiPmon monitor;
void init_pmon();
void init_pmon()
	XAxiPmon_Config *ConfigPtr;
	s32 Status;
	ConfigPtr = XAxiPmon_LookupConfig(XPAR_AXIPMON_0_DEVICE_ID);
	Status  = XAxiPmon_CfgInitialize(&monitor, ConfigPtr, ConfigPtr->BaseAddress);
	if (Status != XST_SUCCESS)
         xil_printf("Initialization failed\n\r");
    xil_printf("\n\r Axi Performance Monitor Initialized");
int main()
	int status;
	u32 PacketCount;
	u32 DataByteCount;
	init_platform();
	//Initializing performance monitor
	init_pmon();
	Xil_DCacheDisable();
	XAxiPmon_ResetMetricCounter(&monitor);
	XAxiPmon_ResetGlobalClkCounter(&monitor);
	status = XAxiPmon_SetMetrics(&monitor, 2, XAPM_METRIC_SET_17,XAPM_METRIC_COUNTER_0);
	if (status == XST_FAILURE)
        xil_printf("Metric Setting failed\n\r");
	status = XAxiPmon_SetMetrics(&monitor, 2, XAPM_METRIC_SET_18,XAPM_METRIC_COUNTER_1);
	XAxiPmon_EnableMetricsCounter(&monitor);
	XAxiPmon_StartCounters(&monitor, 400000000);
	Xil_Out32(XPAR_AXI_PERF_MON_0_BASEADDR,  0x16111210);
	XAxiPmon_StopCounters(&monitor);
	PacketCount = XAxiPmon_GetMetricCounter(&monitor, XAPM_METRIC_COUNTER_0);
	DataByteCount = XAxiPmon_GetMetricCounter(&monitor, XAPM_METRIC_COUNTER_1);
	xil_printf("\n\r Packet Count of Packet Generator = %d", PacketCount);
	xil_printf("\n\r Data Byte Count of Packet Generator = %d", DataByteCount);
	return 0;
Re: ZYNQ Ultrascale+ and Axi Performance monitor
I have attached the screenshot.
Design
@thaus_015,
If you haven't already looked at the examples provided for the axipmon driver, they can be found in the SDK installation at:
...\SDK\2018.3\data\embeddedsw\XilinxProcessorIPLib\drivers\axipmon_v6_7\examples
The actual path may vary depending upon your install and operating system.
Ted Booth - Tech. Lead FPGA Design Engineer
www.designlinxhs.com
Thanks for your response.
I have already gone through that link. But eventhough i am unable to get output from APM. Any idea please.
