axi dma cyclic mode question
currently i'm using
XAxiDma_SelectCyclicMode function
to setup the cyclic mode.
my understand is once its setup, it will run the same dma transfer indefinitely without input from cpu/app?  however, i try it on the sg_simple_poll example, it seem it only run once.  any idea how to set the dma up, so its running teh same transfer repeatly without cpu input?
Re: axi dma cyclic mode question
Did you set the tail descriptor's 'Next Descriptor' field to point back to the first descriptor?
www.xilinx.com
i only has one descriptor, also cyclic mode can only be use in SG?
so address 0 for SG engine is point to it self
Well what's the 'Next Descriptor' field set to for that one? I'm not sure how well this will work... just thinking it through in my head, funny things might happen when the DMA engine tries to fetch the same descriptor from memory once it's done with its local copy. Which happens to be the same thing haha. I think something will be stale and there will be contention.
Try with 2 descriptors.
Yes. Cyclic only works in SG mode.
www.xilinx.com
so the TX/RX BD space has 0xFFF(sg_sample_poll.c example), base on this the BD calculate quite few BD descriptor.
the BD descriptor are store in BRAM has base address of 0x80000000, which contain next BD ptr at 0x80000040, so on to FC0, at which store/point back to 0x80000000.
I use selectcyclicmode function to enable both s2mm/mm2s.  then
Xil_Out32(0x40400010,0x00000050)...... etc to write the tail descriptor for s2mm/mm2s, Axi dma base addr=0x40400000
however, the design still only run once.  i try to trigger on tlast of mm2s stream, it just waiting to armed.  this is a loopback between mm2s/s2mm
Hmm, sounds like your setup should be fine.
Can you probe the SG interface and post some screenshots? It'd be interesting to see what happens when it reaches the last descriptor.
www.xilinx.com
Observer l.sara_tg
Dear all,
I have the same problem with AXI DMA in CYCLIC mode.
I have used XAxiDma_SelectCyclicMode function to setup the cyclic mode in both TX and RX direction,
I have set  the Tail Descriptor register with some value which is not a part of the BD chain (in my case 0x40).
Now I see on FPGA chipscope that DMA is correctly cycling,  but when the software calls RxCallback at line
    BdCount = XAxiDma_BdRingFromHw(RxRingPtr, XAXIDMA_ALL_BDS, &BdPtr);
BdCount is different from NULL only during first occurrance, then it is always NULL because RingPtr->HwCnt = 0,
PostCnt = 1024
AllCnt = 1024
Why does it happens?
What do I have to  do in order to keep DMA in cyclic mode and to read data ?
Looking forward to receiving your help
best regards
Sara
Visitor vlenoir
I get exactly the same issue and I found many thread with similar problem but no answers. Does somebody from Xilinx has an idea ?
Best regards,
Vincent
If memory serves me correctly, tlast will trigger a completion. Without tlast, the descriptor will continue to be looped upon but the dma will never complete and cause an irq.
I believe the UG for axi_dma touches on the subject. Search for 'tlast'.
Visitor vlenoir
Not read so much about tlast in AXI DMA documentation (PG21), it's mainly about 2-D transfers. In my case I can easily control the block length as the tlast is generated by a counter. Assuming for instance tlast events every 32 kB of data and IRQ threshold set to 2 I get indeed IOC interrupts every 2 transfers and the actual transfer length returned by the completed BD corresponds to those 32 kB, but only for one cycle. Then even if the IOC occurs there is no more completed BD. One solution is to set the BD ring size to the length of the cyclic chain but in that case, starting from the second cycle, the whole chain is returned as completed at every IOC interrupt instead of 2.
Visitor vlenoir
I've dumped the completed BD in the IOC interrupt callback and as expected the completed bit in the status field in set but therefore I'm wondering how this bit is cleared for the next cycle ? What I'm guessing, which is what I observe, is that once the first cycle is done the DMA SG engine fetch the first completed BD whose completed bit is already set and go directly to the second BD and so on until the new cycle.
XAXIDMA_IRQ_IOC_MASK
bd_count = 5
radio_if_dma_rx_s2mm_done = 5
Dump BD 1C120000:
        Next Bd Ptr: 1C120040
        Buff addr: 18100000
        MCDMA Fields: 0
        VSIZE_STRIDE: 0
        Contrl len: 30D400
        Status: 8C30D400
        APP 0: 0
        APP 1: 0
        APP 2: 0
        APP 3: 0
        APP 4: 0
        SW ID: 18100000
        StsCtrl: 0
        DRE: 4
invalidate CPU1 L1 data cache (3200000 bytes @ 0x18100000)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x1840D400)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x1871A800)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x18A27C00)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x18D35000)
bd_count = 5
radio_if_dma_rx_s2mm_done = 10
Dump BD 1C120140:
        Next Bd Ptr: 1C120180
        Buff addr: 19042400
        MCDMA Fields: 0
        VSIZE_STRIDE: 0
        Contrl len: 30D400
        Status: 8C30D400
        APP 0: 0
        APP 1: 0
        APP 2: 0
        APP 3: 0
        APP 4: 0
        SW ID: 19042400
        StsCtrl: 0
        DRE: 4
invalidate CPU1 L1 data cache (3200000 bytes @ 0x19042400)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x1934F800)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x1965CC00)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x1996A000)
invalidate CPU1 L1 data cache (3200000 bytes @ 0x19C77400)
bd_count = 0
bd_count = 0
bd_count = 0
bd_count = 0
bd_count = 0
@l.sara_tg
I think your issue and @vlenoir's might be a little different than the original.  This may be a known issue with the example driver.  I gave a way to fix this to @vlenoir in a seperate post, but I wanted to link you to it here.  Forum post:
https://forums.xilinx.com/t5/AXI-Infrastructure/AXI-DMA-SG-Cyclic-mode-BD-ring-size-vs-BD-allocated-number/m-p/938939/highlight/false#M44052
In that post vlenoir gives his fix code (which is almost identical to the code I have used).  I elaborate further on to add that you should only clear the Completed bit when in Cyclic mode (this can be accomplished by a simple 'if (RingPtr -> Cyclic) ...').
Caleb
Caleb
