Observer bondylep
axi_vip could not set data beat. allocated size * is too small for beat n
when I simulate zynq 7000 with zynq7000 VIP, use datamover IP, some cmmand length will error  ncsim: *F,WARSEV (/opt/Xilinx/Vivado/2017.2/data/ip/xilinx/axi_vip_v1_0/hdl/axi_vip_v1_0_vl_rfs.sv,4408):
axi_vip_v1_0_2_pkg::axi_transaction.set_data_beat
[AR_REACTIVE_0] (axi_vip_v1_0_2_pkg::axi_transaction.set_data_beat) 4319 ns : Could not set data beat. Allocated size 64 is too small for beat ( 8).
can anybody tell me what does it mean?
Re: axi_vip could not set data beat. allocated size * is too small for beat n
Hi @bondylep,
Two thoughts for what you might be running into:
1. Is your data mover attempting to read from the Zynq 7000 PS DDR? It looks like there is a problem with the ARSIZE field in the read request.
2. There were a lot of issues with the slave ports in the Zynq 7000 VIP that were fixed in the 2018.1 release. The specific error you are running into does seem valid, though. However, as you continue to develop your test bench it would be best to upgrade to 2018.1 or 2018.2.
Deanna
Hi @bondylep,
Deanna
Observer bondylep
I updated the vivado to 2018.2 by your suggesetion. but i encounter new problem, the zynq 7000 VIP API pre_load_mem_from_file does not have function, it is ok in 2017.2.
thank you for your help
Observer bondylep
 I have check the ZYNQ7000 source code,it is becasue the new VIP mode pre_load_mem_from_file task add to check the address scale, my address is out of scale.
I hope the user can see as more source code as possible, so i can debug it bymyself.
Visitor haitao73
hi,
   I'm using zcv104 evaluation borad, and the i encountered the same issue. I reduce the axi4 read outstanding num to 2, and the issue is dispeared.
