Visitor jangoris1
cascade block design
i was wondering if it is posible to cascade and split block designs.
I have a master block design, which has an axi master and an axi interconnect to connect 4 axi slaves.
Then i have a subdesign of which i will connect 4 identical instances to this master. I would like to be able to use a block design inside this subdesign with an interconnect of its own.
The subdesign has a uart and gpio, within the subdesign blockdesign i use address editor to assign address 0x00000000 to the uart and 0x00001000 to the GPIO.
Then in the master block design i define the addresses as
Master1: address 0x00000000
Master2: address 0x00010000
Am i correct to say that now i can address master 0 gpio at 0x00001000 and master2 gpio at 0x00011000 etc .?
Thanks in advance
Jan
Re: cascade block design
Yes- you should be able to do it. For optimal timing, make sure that each subsystem is a 2^n sized and 2^n aligned address space.
For example, your map might be:
Sub0:
uart:0x0-0x007fff
gpio:0x008000-0x00ffff
sub1:
uart:0x100000-0x107fff
gpio:0x108000-0x10ffff
sub2:
uart:0x200000-0x207fff
gpio:0x208000-0x20ffff
sub3:
uart:0x300000-0x307fff
gpio:0x308000-0x30ffff
This will yield compact address mapping and some room to grow.
