04-01-2020 02:32 AM
I've recently installed an Alveo u250 card that seems to be running fine.
I'm running on the following OS:
Ubuntu - VERSION="18.04.4 LTS (Bionic Beaver)", Kernel= 4.15.0-91-generic
I've installed the XRT, deployment and development target platforms and successfully flashed the card's firmware.
I’ve connected the micro USB and verified that the device is recognized by the OS (see below) but I have no targets in the HW manager under the localhost.
Am I missing anything? any additional drivers I might need to install?
USB-DEVICE:
T: Bus=01 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 11 Spd=480 MxCh= 0
P: Vendor=0403 ProdID=6011 Rev=08.00
S: Manufacturer=Xilinx
S: Product=A-U250-A64G
S: SerialNumber=2132049BF006
C: #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
Bus 001 Device 011: ID 0403:6011 Future Technology Devices International, Ltd FT4232H Quad HS USB-UART/FIFO IC
Ido
04-05-2020 03:24 AM
Issue solved by reinstalling the cable drivers after unplugging the micro USB.
Ido
04-01-2020 08:03 AM
Hi @IdoNB
The card might have come programmed from the factory with a golden image. This golden image has a PCIe core and a path to the QSPI for flashing the full platform.
Can you detect the card using the LSPCI tool?
$lspci -vd 10ee:
Can you see a blue light on the card?
Have you ever used the hardware manager successfully on the computer in question?
Do you have FTDI drivers installed on the machine connected to the card via JTAG?
M
04-01-2020 09:24 AM
Hi @mcertosi , thanks for your replay!
The card did came with a golden image and I've updated it's firmware as instructed in the getting started guide (ug1301). it is now running:
Card [0000:01:00.0]
Card type: u250
Flash type: SPI
Flashable partition running on FPGA:
xilinx_u250_xdma_201830_2,[ID=0x5d14fbe6],[SC=4.2.0]
Flashable partitions installed in system:
Yes, I can detect the card using lspci:
01:00.0 Processing accelerators: Xilinx Corporation Device 5004
Subsystem: Xilinx Corporation Device 000e
Flags: bus master, fast devsel, latency 0
Memory at 62000000 (64-bit, prefetchable) [size=32M]
Memory at 64000000 (64-bit, prefetchable) [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [60] MSI-X: Enable+ Count=33 Masked-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [1c0] #19
Capabilities: [400] Access Control Services
Capabilities: [410] #15
Kernel driver in use: xclmgmt
Kernel modules: xclmgmt
01:00.1 Processing accelerators: Xilinx Corporation Device 5005
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at 60000000 (64-bit, prefetchable) [size=32M]
Memory at 64020000 (64-bit, prefetchable) [size=64K]
Memory at 50000000 (64-bit, prefetchable) [size=256M]
Kernel driver in use: xocl
Kernel modules: xocl
Unfortunately I'm not near the PC at the moment so I'll be able to check for the blue light only tomorrow (will update).
This is the first time I'm trying to use the HW manager on this copmuter.
I have installed the FTDI drivers (but I'm not sure how to verify that it was properly installed).
Ido
04-01-2020 11:03 AM - edited 04-01-2020 11:53 AM
Hi @IdoNB,
EDIT - also try a reboot if you just installed the FTDI drivers.
Looks like the card is working. That's good. Some of the older shells disabled the JTAG port if there is a shell programmed. The number 2018_3 in the shell name indicates it is old, even though it is the most recent version of the shell available to you. I recall one revision of the shells had a power on condition too, where the JTAG cable needed to be plugged in before power was applied to the card. You could test this with a cold reboot. Since this is old functionality though, it could be more reliable to update the shell.
If you just want to see the card in hardware manager, you can use the virtual JTAG cable over PCIe if you need to debug. UG1281 would instruct you to use sdx_debug_hw. I like to do it manually with the following commands
6. Start the xvc server (source xilinx tools) a. $ xvc_pcie -d /dev/xvc_pub.mxxxx //replace .mxxxx the value specific to your machine in /dev/ //you should be able to tab complete 7. In a new terminal - Start the hardware server (source xilinx tools) $ hw_server -e "set auto-open-servers xilinx-xvc:localhost:10200" -e "set always-open-jtag 1" In a 3rd terminal source Vivado tools, and open the Vivado gui.
once that is connected, you can open vivado hardware manager from whichever computer is controlling your terminals.
You shouldn't reprogram the FPGA using xvc though, because it will kill the PCIe link and take the server down. This will cause unpredictable behavior.
M
04-05-2020 03:24 AM
Ido
05-18-2020 06:53 PM - edited 05-18-2020 06:55 PM
I am having the same issue and this discussion has been really helpful.
My setup is very similar to the one described in this thread. To summarize:
Ubuntu 18.04
I can detect the card with lspci, see the blue light on the card, and I have never used the hardware manager on this machine before.
So my suspicion is that I do not have the right driver installed. Could you please clarify what drivers you are referring to? My understanding is FTDI usb drivers, but I believe those come per-installed on ubuntu 18.04. Am I missing something here?
If it helps here is my usb-devices output:
T: Bus=03 Lev=01 Prnt=01 Port=04 Cnt=01 Dev#= 3 Spd=480 MxCh= 0 D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1 P: Vendor=0403 ProdID=6011 Rev=08.00 S: Manufacturer=Xilinx S: Product=A-U250-A64G S: SerialNumber= C: #Ifs= 4 Cfg#= 1 Atr=80 MxPwr=100mA I: If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio I: If#= 1 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
I: If#= 2 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio I: If#= 3 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
Thanks a lot in advance,
05-19-2020 12:32 AM
Hi @ddesigner_821,
Try running the "install_drivers" script, make sure the cable is unplugged first.
You can find the script in:
/tools/Xilinx/Vivado/2019.2/data/xicom/cable_drivers/lin64/install_script/install_drivers/
05-22-2020 04:58 PM
