yangdongsen
Alevo U200 xbutil validate failure
Recently,I used the U200 card to run the demos in the pages of Xilinx on Github.Such as bloom and convolution.(2020.1 ver)
However, when I got down to hardware-simulation, the time that run on FPGA is much longer than that run on CPU.So I realized that something might go wrong with the card.
The message seemed to be right with command
[sudo lspci -vd 10ee:] and [sudo /opt/xilinx/xrt/bin/xbmgmt flash --scan]
But [/opt/xilinx/xrt/bin/xbutil validate] didn't return right message.
The wrong message is as follows:
INFO: Found 1 cards
INFO: Validating card[0]: xilinx_u200_xdma_201830_2
INFO: == Starting Kernel version check:
INFO: == Kernel version check PASSED
INFO: == Starting AUX power connector check:
INFO: == AUX power connector check PASSED
INFO: == Starting PCIE link check:
INFO: == PCIE link check PASSED
INFO: == Starting SC firmware version check:
INFO: == SC firmware version check PASSED
INFO: == Starting verify kernel test:
..Host buffer alignment 4096 bytes
Compiled kernel = /opt/xilinx/dsa/xilinx_u200_xdma_201830_2/test/verify.xclbin
Shell = xilinx_u200_xdma_201830_2
Index = 0
PCIe = GEN3 x 16
OCL Frequency = 300 MHz
DDR Bank = 4
Device Temp = 39 C
MIG Calibration = True
Finished downloading bitstream /opt/xilinx/dsa/xilinx_u200_xdma_201830_2/test/verify.xclbin
CU[0] hello:hello_1 @0x1800000
[0] bank0 @0x4000000000
[1] bank1 @0x5000000000
[Errno 5] Input/output error
FAILED TEST
terminate called after throwing an instance of 'xrt_core::error'
what(): failed to close ip context
Aborted (core dumped)
ERROR: == verify kernel test FAILED
INFO: Card[0] failed to validate.
ERROR: Some cards failed to validate.
I try to find similar problem resulting in vain.So I offer the detail in order to get more useful solution from your group.
Looking forward to your early reply!Thanks.
emeryw
Hi @yangdongsen ,
Glad to hear the system seems to be working better; that validate output looks good.
Best,
-Emery
emeryw
Hi @yangdongsen ,
Thanks for reaching out. From the validate output, I see an
listed. From https://linuxpip.org/errno-5-input-output-error/ , it seems to be a generic error most commonly associated with file system issues. Would you mind posting the outputs of 'sudo xbutil query' and 'sudo lspci -vd 10ee:'?
Additionally, are you able to manually program the xclbin onto the card using 'xbutil program -p [your xclbin]'? Have you tried this card in another host machine?
Best,
-Emery
yangdongsen
Thank you for your reply!
Now I am very confused because when I open the server and run the same command [/opt/xilinx/xrt/bin/xbutil validate]again. It suddenly returns the right message.
I regret not rebooting the server at that time.Although I don't know the reason for the error, I think maybe I can get down to my business again with the card.
Here is the right message.
emeryw
Hi @yangdongsen ,
Best,
-Emery
