farazk
Alveo 200 validate kernel hangs
I am trying to install and validate a new U200 board on a Centos 8 server.
Following are the details:
lsb_release -a
LSB Version:	:core-4.1-amd64:core-4.1-noarch:cxx-4.1-amd64:cxx-4.1-noarch:desktop-4.1-amd64:desktop-4.1-noarch:languages-4.1-amd64:languages-4.1-noarch:printing-4.1-amd64:printing-4.1-noarch
Distributor ID:	CentOS
Description:	CentOS Linux release 8.2.2004 (Core)
Release:	8.2.2004
Codename:	Core
Now it gets stuck when i try to validate the card
 /opt/xilinx/xrt/bin/xbutil validate
INFO: Found 1 cards
INFO: Validating card[0]: xilinx_u200_xdma_201830_2
INFO: == Starting Kernel version check:
INFO: == Kernel version check PASSED
INFO: == Starting AUX power connector check:
AUX POWER NOT CONNECTED, ATTENTION
Board not stable for heavy acceleration tasks.
WARN: == AUX power connector check PASSED with warning
INFO: == Starting Power warning check:
INFO: == Power warning check PASSED
INFO: == Starting PCIE link check:
INFO: == PCIE link check PASSED
INFO: == Starting SC firmware version check:
INFO: == SC firmware version check PASSED
INFO: == Starting verify kernel test:
strace /usr/bin/python3 /opt/xilinx/xrt/test/22_verify.py -k /opt/xilinx/dsa/xilinx_u200_xdma_201830_2/test/verify.xclbin -d 0 2> output
Host buffer alignment 4096 bytes
Compiled kernel = /opt/xilinx/dsa/xilinx_u200_xdma_201830_2/test/verify.xclbin
Shell = b'xilinx_u200_xdma_201830_2'
Index = 0
PCIe = GEN3 x 16
OCL Frequency = (300, 500) MHz
DDR Bank = 4
Device Temp = 39 C
MIG Calibration = True
Finished downloading bitstream /opt/xilinx/dsa/xilinx_u200_xdma_201830_2/test/verify.xclbin
CU[0] b'hello:hello_1' @0x1800000
[0] b'bank0' @0x4000000000
[1] b'bank1' @0x5000000000
Original string = []
Issue kernel start requests
Now wait for the kernels to finish using xrtRunWait()
Any pointer on how to resolve this will be really helpful. Not sure how to proceed.
farazk
Further details:
lspci -vd 10ee:
17:00.0 Processing accelerators: Xilinx Corporation Device 5000
Subsystem: Xilinx Corporation Device 000e
Flags: bus master, fast devsel, latency 0, NUMA node 0
Memory at b2000000 (64-bit, prefetchable) [size=32M]
Memory at b4000000 (64-bit, prefetchable) [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [60] MSI-X: Enable+ Count=33 Masked-
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [1c0] #19
Capabilities: [400] Access Control Services
Capabilities: [410] #15
Kernel driver in use: xclmgmt
Kernel modules: xclmgmt
17:00.1 Processing accelerators: Xilinx Corporation Device 5001
Flags: bus master, fast devsel, latency 0, IRQ 92, NUMA node 0
Memory at b0000000 (64-bit, prefetchable) [size=32M]
Memory at b4020000 (64-bit, prefetchable) [size=64K]
Memory at a0000000 (64-bit, prefetchable) [size=256M]
Kernel driver in use: xocl
Kernel modules: xocl
/opt/xilinx/xrt/bin/xbmgmt flash --scan
Card [0000:17:00.0]
Card type: u200
Flash type: SPI
Flashable partition running on FPGA:
xilinx_u200_xdma_201830_2,[ID=0x5d1211e8],[SC=4.2.0]
Flashable partitions installed in system:
emeryw
Hi @farazk ,
Thanks for reaching out. I see you have CentOS 8.2, what version of XRT are you using, and where did you obtain XRT from (product page, Github, etc.)?
As per https://www.xilinx.com/support/documentation/sw_manuals/xilinx2020_1/ug1451-xrt-release-notes-20201pu1.pdf, CentOS 8.2 is not in the list of supported OS's. Have you tried to obtain and build the XRT source for your OS?
Have you tried running validate on a supported OS?
Best,
-Emery
