[Alveo U250] Flashable partition running on FPGA version
Hello, I think I've got some trouble with Alveo U250 card installation.
When I tried [xbutil validate -d <card_bdf>] command, I got following messages.
Before I deploy my cards, I'm worried about
"SC firmware running on board: 3.1. Expected SC firmware from installed Shell: 4.2.0"
line on my messages.
Can you give me some help to install proper SC frimware Shell?
Additionally, if I command [xbmgmt flash --scan], I got following messages.
Thank you.
Hi @Yeo-Reum ,
You can see from your  [xbmgmt flash --scan] output that the shell installed on your system has SC firmware 4.2.0 with it. All we have to do is flash the SC. To do that, simply run:
sudo xbmgmt flash --update
You'll see something similar to the following:
                                Card [0000:3d:00.0]:
                               Status: SC needs updating
                               Current SC: 3.1
                               SC to be flashed: 4.2.0
                Are you sure you wish to proceed? [y/n]:
Proceeding will update the SC firmware. Then you should no longer receive that warning.
Let me know if you have any questions.
Best,
-Emery
Hi @Yeo-Reum ,
                               Current SC: 3.1
Best,
-Emery
Thank you so much, @emeryw .
Do I have to cold reboot again after updating the SC firmware?
Hi @Yeo-Reum ,
The usual cold boot is done after flashing a shell onto the card. In this instance, we updated just the firmware of the satellite controller. During that process, the satellite controller is restarted automatically when the flash is complete, so no further actions are needed.
Best,
-Emery
Oh, I see! Thank you so much @emeryw .
