gi4you
Alveo U50 No card is found!
I am trying to setup Alveo U50 in my workstation.
OS is RHEL 8.3
I installed xrt and platforms for setup. But I can’t scan and see the U50 board.
Any suggestions?
$sudo lspci -vd 10ee:
[sudo] password for xxx:
01:00.0 Processing accelerators: Xilinx Corporation Device d020
Subsystem: Xilinx Corporation Device 000e
Flags: fast devsel, IRQ 11
Memory at f0000000 (64-bit, prefetchable) [disabled] [size=32M]
Memory at f2000000 (64-bit, prefetchable) [disabled] [size=128K]
Capabilities: [40] Power Management version 3
Capabilities: [48] MSI: Enable- Count=1/1 Maskable- 64bit+
Capabilities: [70] Express Endpoint, MSI 00
Capabilities: [100] Advanced Error Reporting
Capabilities: [1c0] Secondary PCI Express
Capabilities: [1f0] Virtual Channel
Capabilities: [e00] Access Control Services
$ sudo /opt/xilinx/xrt/bin/xbutil validate -d 0
ERROR: Card[0] not found
$ sudo /opt/xilinx/xrt/bin/xbmgmt flash --scan
No card is found!
JohnFedakIV
Hi @gi4you ,
Based on the lspci output, the drivers aren't in use - the last two lines of the lspci output should be:
Kernel driver in use: xclmgmt
Kernel modules: xclmgmt
Do you have the log of the XRT installation? There may be errors that don't cause the XRT installation to fail out.
I should also note that 8.3 isn't yet supported by the XRT tools (OS support is listed on page 5 of the XRT 2020.2 release notes). Also using a U50 in a workstation is not recommended due to the low airflow - the card may overheat and be damaged.
~John
* Please don't forget to reply, kudo and accept as a solution! *
