Alveo U50 pinout and clocks
I'm starting an Alveo U50 design in Vivado flow. The master XDC file is provided on Xilinx website, but the details about the pinout (i.e, oscillator clock frequency and pinlocs) is still hard to understand with the XDC file. Is there any detailed description for Vivado-based design with U50 card?
@irage_sd and @yosana
XTP576 is very clear, grab it from this link https://www.xilinx.com/products/boards-and-kits/alveo/u50.html#documentation
This should answer your questions.
M
Tags (3)
The released information available is here:
https://www.xilinx.com/support/documentation/boards_and_kits/accelerator-cards/ug1371-u50-reconfig-accel.pdf
UG1371 (and Master XDC) doesn't tell about clock frequency of the on-board oscillators (and even location of HBM reference clock :( )
OK, I should read board files (board.xml and part0_pins.xml) for further details...
Did you found 300 Mhz differential(LVDS) clock pins?
is it cmc_clk_p and  cmc_clk_n?
Thanks and  Regards
M
Tags (3)
@mcertosi
I have gone through it.
My Conclusion: In u50DD Engineering Sample Board. 300MHz board clock is not available. There are 100MHz, 322MHz and 161MHz clocks available. I am correct with my conclusion right ?
Hi @irage_sd
There is no 300 MHz clock on the board. What do you need it for?
M
Tags (3)
@mcertosi
Thanks, I am porting one of my designs to u50DD board. The design required a 300MHz clock. But anyways have made appropriate changes to the design in order to port it to u50DD board. I am generating the 300MHz clock using MMCM block.
