eryk2303
Clk as input in flip flop
I would like to add 5-6 blok for one CLK signal. When I add more then 4 block I have timing errors.
Can I do something like in this photo? And this can help reduce timing errors?
joancab
Advisor
Advisor
That's probably the result of treating clocks as signals.
clocks have dedicated networks to ensure timing is met. If you need to "clock" block B from block A, one approach is to drive an enable signal
joancab
Advisor
Advisor
