matlinsas
Could I use the XRT commands if U200 card is used in the customed Vivado RTL design flow?
I am using the Alveo U200 card in the custom Vivado RTL design flow. I am wondering whether could I use the XRT commands (such as xbutil) ?
I want to query the Card's power using xbutil command, but I write some RTL bitfile into the U200 card.
Any other suggestion?
Matlinsas
JohnFedakIV
Hi @matlinsas ,
No, the XRT commands will only work with one of the pre-built platforms available and not with a Vivado flow.
A couple options are:
~John
* Please don't forget to reply, kudo and accept as a solution! *
