Hikaru_Furuta
Enable Alveo-U250
I've implemented an inference using Alveo-U250, but I found its inference session never work at all.
In order to compare the differences between a session using "On-the-fly quantization" and a session without it,
and to make it sure if Alveo-U250 works correctly or not, I've tried "image_classification_DPUCADX8G.py"(https://github.com/Xilinx/Vitis-AI/tree/master/onnxruntime).
As a result, the time spent on the inferences was almost the same each other.
So I removed Alveo-U250 physically and ran the inference session again, but the results wouldn't change.
In these inference sessions, I've just followed the explanation written in README(https://github.com/Xilinx/Vitis-AI/tree/master/onnxruntime).
Is there any other essential procedures to activate Alveo-U250?
I would like you to teach me how to make Alveo-U250 work.
env:
ubuntu 18
Vitis-AI 1.2
Tags (2)
