First Alveo U280 kernel run: [XRT] ERROR: No devices found
I am trying to run a kernel onthe U280 for the first time.
After compiling for "Hardware", I try to run and I get this error in  xcl::get_xil_devices()
XRT build version: 2.3.1301
Build hash: 192e706aea53163a04c574f9b3fe9ed76b6ca471
Build date: 2019-10-24 20:05:16
Git branch: 2019.2
PID: 31324
UID: 1000
[Fri Nov 22 14:50:59 2019]
HOST: mfgs2
EXE: /home/betto/src/dev1/sortMW/Hardware/sortMW
[XRT] WARNING: No devices found
../libs/xcl2/xcl2.cpp:40 Error calling err = cl::Platform::get(&platforms), error code is: -1
Running in Ubuntu 18.04
Xilinx Vitis IDE v2019.2 (64-bit)
SW Build 2708876 on Wed Nov 6 21:40:25 MST 2019
Fixing this other issue fixed this.
Thanks for your help.
PS: I find terribly annoying that Vitis doesn-t install itself all that it needs, and that I need to patch it and cuddle it at every step.
Hi @benedetto73
Looks like the platform is either not installed in Vitis or there is no target platform loaded onto the FPGA.
You said in a previous post that the 2019.1 target platform was not recognized by Vitis, have you tried the 2019.2 target platform now that you have the u280 installed on your system?
M
Thanks @mcertosi for helping me.
Does the command below clarify that the "platform" is installed on both FPGA and the system?
betto@mfgs2:~$ sudo /opt/xilinx/xrt/bin/xbmgmt flash --scan
Card [0000:01:00.0]
Card type: u280
Flash type: SPI
Flashable partition running on FPGA:
xilinx_u280_xdma_201920_1,[ID=0x000000005da8da6e],[SC=4.2.0]
Flashable partitions installed in system:
xilinx_u280_xdma_201920_1,[ID=0x000000005da8da6e],[SC=4.3.4]
 Hi @benedetto73
Yes, it looks like the Alveo Card is ready.
How did you program the card? What commands did you use?
What project did you build?
How did you tell Vitis to compile for a u280?
M
I completely agree with your thoughts. The intention is to provide a good user experience and your feedback helps.
