THULin
How can I know the "Speed" of the U280 ES1 Board?
When I use Synplify synthesis tools, a "Speed" type should be specified, as shown below.
My board is Alveo U280 ES1, so which Speed should I select?
If it depends on the board I used, how can I get the Speed information from the board?
hongh
The speed of the device on the board is: -2L-e-es1
You can refer to XilinxBoardStore on Github:
https://github.com/Xilinx/XilinxBoardStore/blob/master/boards/Xilinx/au280/es1/1.0/board.xml
hongh
