I am looking for a way to convert a vcu118 project to an alveo250 project.
We want to use the alveo board like an evaluation board.
We did the following:
1step: project setting->general->project device (change from Vcu118 to alveo250)
2step: ip upgrade from IP status.
The IP we use
1.block memory generator
2. AXI interconnect
3. AXI_APB_bridge
4. clocking Wizard
5. DMA/Bridge SubSystem for PCI Express
6. DDR4 SDRAM
There are six like this.
1~3 is expected to be completed with ip upgrade.
It is expected that 4~6 will need to change some settings and convert xdc files.
So, if we match what we expected, we would like to know which document or method to refer to.
Hi @gjwlstjr
There isn't a direct translation between a vcu118 and an alveo250. The pin out and pcie IPs are different.
Please rebuild your project using the board aware flow and IP specific for the Alveo u250 card. See this answer record for getting started reference - https://www.xilinx.com/support/answers/71981.html
It is written in the context of using the qsfp ports, but the flow is the same for all the IP.
M
Tags (3)
