lorenzo_rada
Partition --scan not finding any partition in the system
I have successfully flashed the partition of the alveo u50 and now I am trying to program the shell partition with
sudo /opt/xilinx/xrt/bin/xbmgmt partition --program --name <shell_name> --card <card_bdf>
but I can't get the shell_name using
sudo /opt/xilinx/xrt/bin/xbmgmt partition --scan
because I don't get any output.
When I run:
sudo /opt/xilinx/xrt/bin/xbmgmt partition --scan --verbose
I get:
Card [0000:02:00.0]
Partitions running on FPGA:
xilinx_u50_gen3x16_xdma_201920_3
logic-uuid:
f465b0a3ae8c64f619bc150384ace69b
interface-uuid:
862c7020a250293e32036f19956669e5
Partition info
installation
installed_package_dir: /opt/xilinx/firmware/u50/gen3x16-xdma/blp
installed_package_name: xilinx-u50-gen3x16-xdma-blp
installed_package_release: 2784799
installed_package_version: 1
partition_card: u50
partition_family: gen3x16-xdma
partition_features
pcie
device_ids
5020
role: management_pf
5021
role: user_pf
extended_capabilities: enabled
max_link_speed: gen3x16
subsystem_id: 000e
vendor_id: 10ee
partition_identifiers
interface_uuids
type: exposed
logic_uuid: f465b0a3ae8c64f619bc150384ace69b
partition_name: blp
partition_type: blp
partition_vendor: xilinx
vbnv_override: xilinx:u50:gen3x16_xdma:201920_3
Partitions installed in system:
I have installed all the packages on my computer (Ubuntu 20.04 with Tools Version 2020.2) and I don't now how to find the shell_name.
Thanks in advance
emeryw
Hi @lorenzo_rada ,
Welcome to the forums! The process you described sounds like a DFX-2RP shell: https://www.xilinx.com/support/answers/75975.html where the base shell would be flashed to the FPGA, then the shell partition is programmed. Currently the shell listed in that answer record is the only 2RP production shell available.
Your U50 does not use a 2RP shell, and the output above shows it has the the xilinx_u50_gen3x16_xdma_201920_3 shell installed onto it. To see the shell loaded onto the card as well as the shell installed on the host system, run 'sudo xbmgmt flash --scan'.
Best,
-Emery
emeryw
Hi @lorenzo_rada ,
Best,
-Emery
lorenzo_rada
Thanks, so at the moment only the Alveo u250 has a DFX-2RP shell.
