siriux_liu
Power Measurement on Alveo U50
I'm trying to measure the power of HBM and PL separately.
I'm wondering whether it's possible to measure those power rails?
If Yes, where should I start?
Thanks!
anatoli
Hello @siriux_liu ,
The U50 is rated for 75W, supplied by the motherboard via
  • A 10W 3.3V rail
  • And a 65W 12V rail
The 3.3V rail powers the HBM, while the 12V rail powers the rest of the card (except the SC).
You can use xbutil query to determine if the HBM power is within it’s limits by looking at the 3V3 PEX and 3V3 PEX CURR values, reported in mV and mA respectively.
What do you see in your case?
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
If starting with Versal, take a look at our Versal Design Process Hub and our
Versal Blogs
anatoli
Hello @siriux_liu ,
Please check this pdf file for Alveo U50 that has the card power system explanation section: https://www.xilinx.com/member/alveo-vivado/u50/ug1371-u50-reconfig-accel.pdf
More info can be found in UG1370: https://www.xilinx.com/support/documentation/boards_and_kits/accelerator-cards/1_7/ug1370-u50-installation.pdf#page=32
As you can read, the Alveo U50/U50 LV card has separate power rails for FPGA fabric and HBM memory. image.png
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
siriux_liu
Hi, @anatoli ,
Sorry, it took me a while to get back.
I checked the datasheet and XRT. As you said, the Alveo U50 has separate power rails for FPGA fabric and HBM memory.
However, inXRT(xbutil query), there is no current measurement for HBM.
Did I miss anything?
I'm also checking the XRT source code. Do you have any suggestions? Thanks:)
anatoli
Hello @siriux_liu ,
  • A 10W 3.3V rail
Kind Regards,
Anatoli Curran,
Versal Blogs
siriux_liu
Hi, @anatoli
Thanks so much for your help!
In xbutil query, I could see the 3.3V PEX and 3.3v PEX CURR.
I was confused by the HBM1V2 VOL and VCC1V2 CURR. Do you know where I could find this power rail standing for?
I really appreciate that!
anatoli
Hello @siriux_liu ,
I've just heard back from the Alveo higher level experts team and they have confirmed that HBM1V2 is the voltage of the VCCHBM, however there is no current monitoring of that rail - so power can't be calculated
VCC1V2 isn't on that card, as it displays N/A
e.g.:
And in case anyone else need to know how to calculate the power, the equation to calculate power is
power = voltage * current
From the information provided in the example above HBM is using 8.9W (3.373V * 2.647A).
Hope this helps.
Kind Regards,
Anatoli Curran,
Versal Blogs
