Fason
Problems installing U50
After I correctly installed U50 on the server, I entered the "sudo lspci - VD 10ee:" command in the Linux system terminal, and could not feedback the correct information.
JohnFedakIV
Hi @Fason,
Welcome to the Xilinx Forums!
The Alveo Card Debug Guide has a section on possible scenarios when a card is not recognized by the $sudo lspci -vd 10ee: command:
https://xilinx.github.io/Alveo-Cards/master/debugging/docs/card-not-recognized.html#card-not-recognized-under-lspci
~John
* Please don't forget to reply, kudo and accept as a solution! *
JohnFedakIV
Hi @Fason,
~John
