11-02-2020 04:47 AM
Hi ,
Is it possible to get a bit more information about PCIe memory resources available with U50 standard shell? What each of these ranges is used for?
$ lspci -s 17:00.1 -nn -v
17:00.1 Processing accelerators [1200]: Xilinx Corporation Device [10ee:5021]
Subsystem: Xilinx Corporation Device [10ee:000e]
Flags: bus master, fast devsel, latency 0, IRQ 69, NUMA node 0
Memory at 380070000000 (64-bit, prefetchable) [size=32M]
Memory at 380074000000 (64-bit, prefetchable) [size=128K]
Memory at 380060000000 (64-bit, prefetchable) [size=256M]
Capabilities: <access denied>
Kernel driver in use: xocl
Kernel modules: xocl
This document didn't help me, but probably I've been reading the wrong chapters
11-12-2020 02:34 AM
https://xilinx.github.io/XRT/master/html/security.html#pcie-topology
PCIe Topology
As mentioned before Alveo platforms have two physical function architecture where each function has its own BARs. The table below gives overview of the topology and functionality.
0 | 0 | xclmgmt | Memory mapped access to privileged IPs in the shell as shown in the Figure above. |
0 | 2 | xclmgmt | Setup MSI-X vector table |
1 | 0 | xocl | Access to register maps of user compiled compute units in the DFX region |
1 | 2 | xocl | Memory mapped access to XDMA/QDMA PCIe DMA engine programming registers |
1 | 4 | xocl | CPU direct and P2P access to device attached DDR/HBM/PL-RAM memory. By default its size is limited to 256MB but can be expanded using XRT xbutil tool as described in PCIe Peer-to-Peer (P2P) |
11-12-2020 02:34 AM
PCIe Topology
