11-12-2020 05:55 AM
Hi, I have the license problem, when running Vivado gt_kernel example:
https://www.xilinx.com/member/alveo-platform.html
[Common 17-69] Command failed: This design contains one or more cells for which bitstream generation is not permitted:
level0_i/ulp/eth0/inst/i_ethernet_0/inst/i_xxv_ethernet_0_top_0/i_xxv_ethernet_0_CORE (<encrypted cellview>)
If a new IP Core license was added, in order for the new license to be picked up, the current netlist needs to be updated by resetting and re-generating the IP output products before bitstream generation.
But, I can generate bit stream for the xilinx_u50_qsfp_v1_1 with 10G/25G Ethernet Kernel
How should I deal with this license issue?
11-13-2020 01:05 AM
Hi @JohnFedakIV , @emeryw , could you please have a look on this story?
It's something with IP core license propagation, I tried to open top-level Vivado project, clean it up and regenerate all the cores. But the result is still the same
11-13-2020 03:25 PM
Hi @vconst89 ,
Please only post in one forum, I see you have also posted here:
https://forums.xilinx.com/t5/Installation-and-Licensing/gt-kernel-license-issues/m-p/1172005
That is the correct forum to reach out to regarding licensing related questions. I will provide a couple thoughts there.
~John
