Visibility of PCIe DMA
Hi @bchebrol ,
In host code (vadd.cpp) of vadd example I see that buffers are created to transfer the data from host to DDR , will the PCIe DMA come into the picture during this transfers.
Thanks & Regards,
Mounika.
Tags (2)
bethe
Hi mounika.athuluri1@gmail.com  - the PCIe DMA core is built into the Acceleration Platform as the data path between the host and the card.  So inherently, yes, the data will pass through that core.
Is that means there is no need to keep pcie Dma IP in soc physically..??
bchebrol
Hi mounika.athuluri1@gmail.com ,
The XDMA(Xilinx DMA) comes into the picture while transfering the data from host to DDR.
Vishnu
