acabrera
What is the difference between the Deployment Target Platform and the Development Target Platform?
Hi all,
Could someone clarify for me the difference between the Deployment vs. Development target platform? The difference reported in the Alveo U250 download page says:
"The development target platform is required if you are building your own applications"
Why is this?
JohnFedakIV
Hi @acabrera ,
This is discussed briefly in UG1301 on page 7.
The deployment platform provides the firmware needed to run precompiled applications on the card. It cannot be used to compile or create new applications.
The development platform allows Vitis/V++ to compile an application for the intended platform.
In some cases, the final systems that run the Alveo cards aren't the same as the systems used to do the development work. Having these separated allows a much smaller installation for the final system that is just running the acceleration function. The UG1301 also has different memory requirements depending on the system type.
~John
* Please don't forget to reply, kudo and accept as a solution! *
JohnFedakIV
Hi @acabrera ,
~John
