uplin
Which version of OpenCL the alveo card support? does it support 1.2 or higher?
which version of OpenCL the alveo card  support? does it support 1.2 or higher?
JohnFedakIV
Hi @uplin ,
Welcome to the Xilinx Forums!
Vitis host applications support OpenCL 1.2 (mentioned here: https://www.xilinx.com/html_docs/xilinx2020_2/vitis_doc/devhostapp.html).
For coding the kernels, OpenCL 1.2 is not supported. We have examples of C++ kernels and OpenCL kernels found here: https://github.com/Xilinx/Vitis_Accel_Examples.
~John
* Please don't forget to reply, kudo and accept as a solution! *
JohnFedakIV
Hi @uplin ,
~John
uplin
thank you very much
