XDMA Tandem PCIe Example App on u200
I'm attempting to get a very basic XDMA image build for the Alveo u200 card, with tandem PCIe functionality enabled.  I'm using Vivado 2019.1, because when we tried the same thing with 2019.2 on the vcu118 dev card, tandem pcie was broken, and I was told that the bug was introduced in 2019.2, so I'm using 2019.1 as a workaround.
I built my XDMA IP from scratch, and used the u200 card as the target, then generated the example design, and was able to generate the "design_field_updates.tcl" script for doing the actual build.  I then executed the design_field_updates.tcl script and it gets stuck on a location issue:
ERROR: [DRC HDPR-6] Logic illegally placed: Cell 'sys_reset_n_ibuf/IBUFCTRL_INST' is placed at site 'IOB_X1Y307' which belongs to reconfigurable Pblock 'update_region'.  This cell is not part of the reconfigurable logic assigned to this Pblock, and should not be placed at this site.
ERROR: [DRC HDPR-6] Logic illegally placed: Cell 'sys_reset_n_ibuf/INBUF_INST' is placed at site 'IOB_X1Y307' which belongs to reconfigurable Pblock 'update_region'.  This cell is not part of the reconfigurable logic assigned to this Pblock, and should not be placed at this site.
Seems like the example design should "just work", am I doing something wrong?  If I'm not doing something wrong, what do I need to modify to get past this?
Re: XDMA Tandem PCIe Example App on u200
Based on guidance from @mcertosi , I'm going to post this in the PCIe forum instead.
