Synean
Xilinx fpga u200 Bitstream Linux
Hello i am new at this i am trying to mine ethereum with u200 fpga but how i should do bitstream on linux?
bruce_karaffa
How much do you know about FPGAs?  Do you understand the algorithm you intend to use?  Are you going to write the code yourself or are you going to purchase Intellectual Property (IP) to add to the design to perform the actual decryption?  If you are going to do all of the coding yourself, what language will you use?
Synean
Hello, i have no idea about fpga i am new at it so i can purchase but how or from where should i do?
